Hello, I would not like to completely change my tool path but i would like it to cut less air. Thanks.
Solved by seth.madore. Go to Solution.
@seth.madore Would you be able to help here, or do you know someone who might have some insights?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
@CGBenner thanks for tagging me 🙂
@endicott.12 could you share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
"Rest Machining > From Previous Ops" is your friend here.
Before:
After:
Happy machining!
🙄I should've just clicked buttons and I wouldve eventually found it 😂. Thanks a million
That's typically how it goes, huh 😄
