- Mute
- Permalink
- Report
Hello Forum,
I just had an instance where I could not copy and past a 2D Adaptive op to a different file? I created a set of soft jaws for a job, machined it to check it would fit the part. Then I flipped the soft jaws drawing, did my stock set up but I could not copy and paste the 3 machining ops to make the second half/part? Same tool #s, same stock size, same 0,0 original location. It was only after I made a new 2D Adaptive op on the mirrored part could I copy and past from the 1st part? Is this normal?
