Fusion Manufacture
CHAMFER PROFILE ISSUE
9 REPLIES 9
Message 1 of 10
435 Views, 9 Replies
PLEASE TAKE A LOOK AT THIS, YOU GUYS HELPED WITH ONE VERY SIMILAR I BROUGHT THE SAME TOOL IN FROM THAT ONE THAT WORKED AND USED IT ON THIS PART, I TRIED PATCH AND THE OTHER OPTIONS YOU SENT ME. THIS ONE I JUST CANT FIGURE OUT. PLEASE HELP
I WANT TO CHAMFER AND FACE AND 'NOT' HAVE IT DIVE INTO THE PART.
https://www.screencast.com/t/W2sFLNlGo
9 REPLIES 9
Message 2 of 10
HRTFAB
can you attatch an f3d file
Message 3 of 10
in reply to: HRTFAB
SOMEONE HELPED ME WITH ANOTHER SITUATION JUST LIKE THIS . I ACTAULLY SAVED
THAT TOOL OUT WITH SETTINGS THAT WORKS ON ONE PART BUT I CANT SEEM TO SEE
WHY IT WONT WORK HERE. THE PATCH METHOD SEEMS TO BE THE QUICKEST BUT SINE
I'M NEW THE SKETCHING METHOD MAYBE IS BETTER BUT I CAN'T SEEM TO GET THAT TO
WORK EITHER.. THANKS
Message 4 of 10
APPARENTLY YOU CANT REPLY TO EMAILS ? WELL HERE YOU GO
PLEASE LET ME KNOW IF YOU CAN HELP I'M KIND OF IN A STAND STILL WITH THIS
Message 5 of 10
HAVE YOU GUYS LOOKED AT THIS ? I'M STILL WAITING PLEASE
Message 6 of 10
angelo.juras
Hello @Anonymous - I took a look at your part and fixed what I understood. Please take a look at the attached file and let me know if this is what you need.
One thing to keep in mind, on Profile, if you don't want the tool diving in, make sure Grooving is set to "don't allow grooving"
Facing won't dive in and that is what I used. You also don't need to use patch to cover a hole using these methods.
Message 7 of 10
paul.clauss
Hi @Anonymous
Thanks for posting! My apologies for the late response. I found that adding a Tool Clearance Angle (as described in this article) worked to straighten out the toolpath. I hope this helps! diveavoid.gif
Paul Clauss
Product Support Specialist
Message 8 of 10
in reply to: angelo.juras
ya every time i try that it makes my path red ? any ideas with that ? can you do the "do not groove" to my part and send it to me ? the part attached does the "face" then "chamfer-profile" ... i wanted to do chamfer and then face in one path with "profile" .... well thats what i was trying to do .. thank you !
the video Paul posted worked perfectly !
Message 9 of 10
in reply to: paul.clauss
thank you ! that worked
any ideas why the "sketch" "patch" or anything other ways dont work ?
Message 10 of 10
paul.clauss
Hi @Anonymous
Thanks for the response - I'm glad the tool clearance angle worked! To be honest, I am unsure of why the patch won't work on your part - I ran some tests on my end and found that the sketch and patch workarounds did not appear to be working in a new file I created as well. I've logged a ticket for the CAM development team to look into this behavior - thank you for bringing it to our attention!
While this is addressed, specifying a small tool clearance angle should help you work around this behavior in any file.
Paul Clauss
Tags (1)
Technology Administrators
