Nesting
Nesting
I have multiple CNC machines and would love to see nesting. I currently use Alpha Cam, Router Cim, Xilog, and Holzher Hops to program all my different machines. I think Fusion is ripe for being able to tap into this sector of machining. The ability to share, and posts and all the other features have me chomping at the bit. I have made programs with it on one of my routers, but it would be great to create one nest, and be able to tool it and post depending on what machine I want to send it to. Huge time saver, since the actual nesting takes the most time finding the perfect nest, and its also frustrating not having the machine control in some cam packages (HOPS) to be able to do fancy machining
92 Comments
robin_lindsey
I recently started consulting at a furniture manufacturer and would like to bring Fusion 360 in to help help with some of the CNC'd parts. I think adding a Panel optimization tool wood be a great idea. Example- If a wood shop is cutting multiple pieces of an assembly out of one piece of plywood the user could simply place all of the pieces into the assembly and click optimize and the pieces would be laid out to take up only as much room as necessary.
Tags (7)
Perhaps this scripts helps you (for a while) https://www.youtube.com/watch?v=7SY367qt3YQ&feature=youtu.be
daniel_lyall
thats is coming soon it's called nesting more votes do help to get it higher up the lader
cj.abraham
As the others have said, this is commonly referred to as nesting. We do have future plans to implement nesting functionality.
CAM-6926
Until such time as Fusion gets the Nesting feature finished - anyone that needs nesting done could possibly look at Aspire or Vcarve Pro from Vectric.  If you have the software already you can bring your dxf file into Aspire and do the nesting there.  Once done you can export the file back to dxf and use it in Fusion or just use Aspire to cut the gcode..... if you don't have Aspire, then download the 30 day demo and use that until it runs out.  When that runs out maybe you can download the Vcarve Pro and try it that way.  I don't know if they will pick up on you downloading 2 different packages but it might work for you.  Anyway, it's a work around for now.
wtxrcdog
 Hello Thanks for a great software package. I believe it could be made better for my use on my routers if nesting and v-carving could be included. I now use Vectric software for this. I love to use Fusion and I am trying to make it work on my routers.
 Bruce Hoover
smet_kim
Observer
Please add nesting to fusion 360
daniel_lyall
@wtxrcdog Fusion has Vcarve it's just called engrave but it's the same thing.
wtxrcdog
 I have used the engrave feature before maybe I just need to use it more often to get used to it. It seems like it was a little harder to use.
 Bruce
balunist
I would like to morph this suggestion a bit.  I design and build furniture and got my start in 3D modeling in baby steps using Sketchup to model my furniture.  When a acquired my CNC I moved to Fusion 360 for it's CAM integration and I discovered how productive real CAD software and parametric model could be.  There is one Sketchup plugin that provides functionality missing in Fusion 360.  It's called CutMap which allows you to input both plywood and lumber you have available and when run it would provide a layout of all design components on either plywood or boards of lumber based on component dimension and material it is made of.   It also created a cut list with the quantities and dimensions.
I do all my wood working now in Fusion 360 for both CNC and conventional shop machining and saving the step of exporting designs to Sketchup would simplify things a great deal.
The description of the Sketchup plugin can be found here.    CutMap plugin for Sketchup
colin.smith
Status changed to: オートデスク今後検討
jdawg
I will be glad to test anything you need tested. As I am already trying to
figure out how to configure a post for my Holzher, SCMI, KOMO, and WINcnc
machines
colin.smith
Looking in to a solution. No date for release at this time.
jdawg
I am willing to help Alpha test especially in the arena of post processing
and ease of use.
pbeseda
We're doing all of our shops drawings and designs in Fusion now. This would take Fusion (and our shop) to the next level. Would love to see this and would be willing to test / give feedback at any time.
waiting for it. Can also help with testing or helping with my opinion how I think it should work...
dmorris750
Happy to test on my machines to help make this happen!
This is the biggest area where Fusion is lacking for CAM and Machining!
Really need this to justify using Fusion in the workplace and not just as a hobby tool for messing around.
PLEASE HELP ME kick CabinetVision to the curb by adding this!!!
jdawg
I have been working with a man who seems to be able to write posts for many
of the oddball cnc machines. We are currently sorting out Holzher. It isn't
free, but if it works, it will be worth it.
jbrewlet
This is the ONE feature I'd kill to have in Fusion 360. The only reason I open the crappy software that came with my CNC is to nest.
Please add Nesting to fusion 360 cam.
