Support for Wire EDM cutting would be really appreciated. The plasma function should be half way there.
- 4-axis support "XYUV" from 2 sketches with an offset (top and bottom) would be a good start.
- Changeble Z-Heigh for machines that support that, to be abel to cut diffrent parts without manually change the z height.
- Support to contour a inner/outer-3d surface from a solid model.
- Wire thread and start/end cut points.
- Lean in/out from lines.
- Multiple passes, rough and fine pass (nr of fine passes and stock to leave).
