Hey, while I love Fusion360, I'm a Wacom Tablet and laptop trackpad user. I can't use a mouse because of wrist problems.
The way Direct Entry works in Fusion360 makes it incredibly difficult for me to use.
The way it currently works is that you type in a value, which then sort of 'locks' the current sketch operation to the length entered, then you click to confirm. If you move the mouse a bit, it then cancels out the Direct Entry.
The problem is, it's almost impossible to do the click to confirm without moving the pointer a tiny bit when working with a Wacom or certain trackpads, for the act of returning your hand to the tablet moves the pointer. Even if you attempt to type in a value with your left hand, if your right hand (holding the stylus) even moves a tiny, tiny amount (the 'Pro' Wacom tables are crazy sensitive!) it then cancels out your Direct Entry.
I cannot convey with text alone how annoying this is.
So if there was an option to increase this 'move to cancel' distance or somehow turn it off altogether it would make using Fusion a whole heck of a lot more fun for me.
