Show only
Search instead for
Collapse Command ideally should be assign to a hotkey(.e. Ctrl + Backspace, or Backspace), and it should work with vertices,edges,polygons. In this example I use a polygon:
We are currently working on an update to the Fill Hole command and considering an option to Fill Hole by Collapse which would utilize the capability you are suggesting.
