Viewing long file names in the Data Panel can be a lengthy process...
This problem could be solved in a variety of ways. however the Two that seem to be best fitting are as follows (in order of suitability).
- Wrapping the Text within the White portion of the folder/Part.- Easiest and instantaneous ability to read the required information option and doesn't impact the rest of the screen.
- Manually being able to scale the data panel. - there is no reason it cant take up a larger percentage of the screen, particularly because when in use that is where your focus of attention is and when not in use it can be hidden... With this said simply making it larger wouldn't work for all parties. having the ability to manually enlarge it would suit all. but only if this options uncovers the hidden portion of the file names.
![Datapanel.png Datapanel.png](https://forums.autodesk.com/t5/image/serverpage/image-id/451489i51E87FC0072B7104/image-size/large?v=v2&px=999)
