This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Snap to grid at the edge
Please make grid points at the edge of a body as snappable targets.
Here is an example of a current problem.
1. Make a box with corners at (0, 0) and (100, 100), and with a certain height.
2. Select the top surface of the box, and try to place another box on it with corners at
   (30, 0) and (50, 100).
3. Because we cannot snap the first corner of the second box to the grid point at (30, 0),
    we cannot place the box precisely.
4. Even if we go to sketch mode, still the grid points at the edges are not snappable.
    We thus have to make a rectangular roughly, and then use "Sketch Dimension" to place the corners precisely.
If the grid points are respected at the edges, just as other grid points on the surface, this problem is solved.
Also, if the intersection between the grid lines and the edges are also snappable,
we can place the second box even though the edge of the first box does not follow grid lines.
2 Comments
Snapping needs a big overhaul. There are a ton of cases like this where you can't snap to things that seem like very obvious targets.
promm
Status changed to: RUG-jp審査通過
Thank you for your idea, this is getting archived due to lack of votes.
Mike Prom
