Sketching on curved surfaces
Ok i know this one must be very tricky but sketching on a non flat surface would be incredible !
I know you can project drawings and models on surfaces but it's time consuming when you have to redraw or modify things (for 3D models, you have to unlink everything after projection and its very hard even after unlinking to change anything).
49 Comments
schneik-adsk
Status changed to: オートデスク審査落選
schneik-adsk
Status changed to: オートデスク今後検討
schneik-adsk
Status changed to: Gathering Support
KirillChepizhko
One of the most needed things is this exactly. Working with curved faces .Sketching on curved faces, patterns on curved faces
cekuhnen
Beacuse fusion also has no bend tool
KirillChepizhko
bend tool is one of my suggestions here, is pretty highly voted too. Just needs time to be implemented I am sure.
colin.smith
Advanced Modeling
colin.smith
laughingcreek
What does "Future Consideration" mean?
Back in November auto desk  said this functionality would be in one of the next few releases.  Most other modeling programs I've used already have this type of tool.  It' really useful.
Looking forward to it being added to a release update, soon I hope ?
Yes please, I would love this feature.
snoofydog
Hey Autodesk,
Been a bit quiet on this one lately.
When is sketch on surface going to be released??
Tony
Swissomation
This feature would help us as well.
Gimme Wrap to Surface, Please!?
Agreed! Wrapping sketches onto a curved surface is really useful and it's easy in CATIA (with the right licenses). Please move this one up the priority list!
Like everyone's said, I've also been wishing for this feature to be implimented, several projects I'm working on would benefit from this.
Super inconvenient that I can't wrap an extrudable sketch onto a non-planar surface. Please get this update out ASAP.
Cheers
I would really like this feature too. Either by being able to sketch on a non planar surface or by projecting/wrapping a sketch onto a non planar surface. And i dont mean project to closest point we allready have that but it morhps my sketches when i use this.
The weird thing is that images can be wrapped to surfaces so it buggles me why they didn't implement it for sketches too.
Wrapping images just takes a simple coordinate transform and is a standard feature of 3D rendering engines. Basically just x2 = f(x1) sort of mapping. Very straightforward even if you're doing it for the first time.
Wrapping sketches properly requires differential geometry and there are probably a ton of hidden assumptions about flatness and Euclidian topology baked into the sketch engine that would have to be rethought.
Simple example: a straight line in a flat sketch can be represented by a position and direction. On a curved surface, that is still true but the line becomes a geodesic and if the curvature changes, the geodesic will depend sensitively on where exactly you pick that fixed starting point and direction. Try instead to use two points to define the line and while that uniquely defined a line in a Euclidian sketch, you now potentially have an infinite family of geodesics. Even doing that consistently on the surface of a sphere is tricky and doing it in a way that will seem reasonable and intuitive to the user on arbitrarily curved surfaces that can change geometrically and topologically is highly nontrivial. Try to kludge it with the same coordinate remapping from image mapping and lots of things will break and not work at all reasonably
I see. Thats very informative. Thanks. Smiley Happy
