Hi fusion sheet metal team:
It would be awesome if the sheet metal tool/rules had a mechanism to automatically insert a bend alignment feature in the flat pattern for manual braking.
Right now I unfold after the sheet metal part is designed and add a tangent half circle to the outer edge of each bend. This way when the pattern is cut there's a feature that can be aligned with the die to get the bend in the right location without a lot of tedious measurement:
More automation means less human error. Thanks for considering!
