Please add import to INSERT menu; very non-intuitive as is
I spent hours trying to figure out how to import a component from a file into a new design.  The main reason this took so long was that in the early days, or maybe still on PCs, not sure, there was some other menu command, and that is still today  the most common result in google searches (e.g. "fusion 360 import component").  These old videos and forum posts need to be deleted or notated.
Here is what I finally found:  Go to the top level of the data panel and RIGHT-CLICK on the letters of the file name you want to get the menu that allows import (the letters don't highlight and appear active, and I believe if you click on the file's image it doesnt' work at all).
Why is this action not present on any obvious pull-down menu? I'm sorry, I know I'm supposed to civil, but really, how COULD you s/w engineers have done anything so obscure and non-intuitive as to require a right click on something not normally visible when you are designing?
It is intuitive that design import commands should be on the file> and insert> menus.  Please, please add them there and please keep in mind the goal of making the software more easy to use and intuitive. A command should NEVER be off the main menus, thatmakes your software impossible to learn and discover. (They are fine as Shortcuts.)
-BTP
import - contextual menus - insert menu - import design - import component - easy of use - intuitive interface
4 Comments
kb9ydn
You can also left click and drag files from the data panel.
But you're right, there should be an "insert from file" in the insert menu and in the file menu.
C|
TrippyLighting
@thepirate1
The user interface in general and how to insert components from the data panel into an existing design is covered in the video tutorials in the learnig section. It offers 9 tutorials in less than 50 minutes. You could have easily saved hours of your valuable time.
The learnig section is "hidden" behind the elusive "Learn" button on top of the forum page. I find that very intuitive loction for that button and the button desription is also fairly descriptive.
colin.smith
This item has been archived due to a lack of votes. If you feel this item is important feel free to create a new idea station item.
colin.smith
Status changed to: RUG-jp審査通過
