2D Hole Dimensioning
Make an option in the Feature Hole command to measure from 3D walls on the model for Direct modeling mode. And in Parametric modeling mode it would automaticly create a sketch to reference.
I hate holes : )  Also, it would be nice to have the SHCS sizes pre-loaded in the hole command. Or, just an option that when you select it, it solve the proportions like:
"Select" - SHCS - or - Counter Sink - Metric - english -
3/8 hole
Then it would solve
1. Counter Bore depth 105% of thr Hole Ø
2. Counter Bore Ø = 150% hole Ø
Then, there is no need to go through a big list.
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
