Pipe wall thickness direction - inside/outside diameter
Hello.
Fusion 360 has a 'Pipe' extruding tool which is great. Removes the need for a profile sketch and sweep action.
It asks for an outside diameter and a wall thickness if made hollow.
But sometimes an inside diameter is important.
Simple inversion of the wall thickness dimension could do the trick, although at the moment negative values don't work.
Currently the tool name should actually be 'Tube' not 'Pipe'. From Google: "Tube is measured by outside diameter, pipe is measured by inside diameter."
Thank you!
1 Comment
True.
