CAM: Clean up patterned toolpath Setup Sheet output
I thought I was so sneaky when I figured out that I could pattern tool paths, and even pattern those patterns! It works great as far as I can tell, but when it comes to trying to have Fusion output a Setup Sheet, things get a little wacky...
I have 4 tools in this setup, but because of the patterning it somehow sees it as 162 separate tool instances and shows them all in the Setup Sheet.
Obviously this is not ideal. I really only need the tool descriptions 1 time each, and instead having it dozens of times makes the Setup Sheet fairly worthless.
I looked at the basic settings for the Setup Sheet, but could not find anything that looked promising. This seems like it should be a pretty easy fix (for someone who knows what they are doing in Java...), but alas, that is not me.
Thanks for looking into this!
-Jon
