Optimize for CNC, laser and 3-d printing
I would be nice to have if Fusion 360 will let you optimize a file which will be CNC milled.
This feature could let you choose the material that is going to be milled. Then it should show or let you if know whether a part is too thin/weak, after that it should give the user some options on what you what to do. For example, some of the options could be that to go back and change the thickness or change the thickness for you automatically.
This idea can be implemented for 3d printing parts as well, in the same way, the feature could ask what type of material it's going to be printed as, then it could what microns its printing to, and then do the same as what I have said above.
Thanks, and Keep creating.
