Emboss Feature
Emboss Feature
I am coming from TurboCAD where changing the size of a part could be done by either moving with the mouse or entering in the field the desired change.  As an example, in TurboCAD they have three fields showing for a curve; radius, diameter, distance.  This made the manipulation very simple.  Right now it is very difficult when trying to make adjustments.  If I select a curved surface we're given the arrow to move with a mouse or the field in which to enter the delta.  I don't want to have to run numbers with my calculator to figure out what I am thinking of in terms of diameter, divide by two to get radius, then subtract from what Fusion is showing as the radius.  I should be able to click on the face and have it show the values of the radius and diameter (in the case of a curve) and enter in a new value for whatever I want it to be.  The process would be similar for other shapes.  There are too many steps involved in simple changes.
