Nested Sketch Patterns
I would like to have the ability to Pattern a Pattern in a Fusion 360 sketch environment.
When creating a pattern the user is prompted to select "Objects." I would like to be able to select the sketch pattern as an object to pattern.
The benefit is to enable better parametric updates for nested sketch patterns.
Reference below discussion for further context.
http://forums.autodesk.com/t5/design-and-documentation/fusion-don-t-rebuild-patterns-after-editing-b...
6 Comments
TrippyLighting
The sketch pattern tools can use a good number of improvements. I've posted at least three other ideas.
cekuhnen
@innovatenate I fully agree - this is highly needed. Below you see one block the edges are rounded then I add an array to make 4 copies, another array adds a copy above and a 3rd array makes 2 more copies form. The rest then is passed into a bend modifier and mirrored over to the other side of the coffee maker.
Very efficient and effective. Fusion needs to have at least the ability to stack arrays in a simmilar and fast way for sketch and objects.
maritza.ga
Status changed to: オートデスク今後検討
maritza.ga
There is quite a work required to make this a reality. I will log it in our backlog and discuss bandwith.
haughec
I would also like to see this feature come to life.
Thanks!
Mitch
