Changing CAM units
Changing CAM units
When you change units under preferences, the changes don't go into effect in the CAM panel until you start a whole new file. Saving your existing file as a file with a new name does not work either.
3 Comments
scottmoyse
I personally wouldn't want it to change the units on pre-existing files automatically. But it is super easy to change in the UI if you need to.
Jonathan_Kolodner
I would suggest that having "document level" unit choices would be great, or even having both units shown in a field, the primary units are selectable and render as black on the white field, while the alternate units are in the white space adjacent, are not selectable, and are a mid-tone gray.
al.whatmough
Status changed to: RUG-jp審査通過
