Good morning,
I see I'm not the only one to have problem with units in model. All settings are imperial (in, lb...). The problem is with properties that still remain in ouncemass (with my actual setting it would be lb and not oz). The same problem has been reported about a year ago
https://forums.autodesk.com/t5/fusion-360-design-validate/physical-properties-changing-ouncemass-to-...
For each component we click on, it will also be nice to have in upper menu many variable we always use (lbs, material, appearance...)
I saw in old tutorial you already had material appearing on upper menu. It seems it disappeared with time ???
For each time we spend to pick properties at each request, it will be easier to see directly at top menu
thanks
