measure angle two face of solid
Hi
I noticed when I used the Fusion 360 I can not measure the angle between two faces I selected
it would be better if I could see angle between two faces 🙂
2 Comments
I get your point. But Fusion 360 just can't measure it for all kinds of faces. If the yre not bended like in your example fusion can show the angle. Check my example, and you can see the wanted data.
Gokhan_Kaya
hi @lichtzeichenanlage
thanks for help my problem yes I can see angle on your exam models but I want to  see angle my exam model   because when designing I sometimes need to measure between for control purposes I create drawing then measure this angle
I can see this angle value somehow
it would save time to measure directly 🙂
