I'd like to see the extrude command be smarter. If it's the first body created, it can go any direction as it does now. If it's the second body with a sketch drawn on the first body, it should extrude away from the first body as the standard, or if cut is selected, into the body the sketch is drawn on. Seems like the direction the program chooses is always backwards and requires extra steps to get it right.
