mcMaster-carr window size
hello friends,
every time i use mcMaster-carr i need to resize that window. can you store that size in your fusion360 config. i use a 4k display and it shows 15x9cm very small, see image. thanks
4 Comments
kraaienburg
I recommend going to mcMaster-carr's website on a normal browser and the after finding the product code just paste into search bar in Fusion's mcMaster window. The window is a bit small but this workaround helps quite a bit.
Garret_H
2nd this.
I also find browsing for parts in that window quite clumsy, there doesn't seem to be an actual back button to return to your previous menu selection.
charles_alexander
Agree..Its only a few lines of code to make the window size retentive...
-Need a "Stuff that slows me down" forum page... 🙂
>> "-Need a "Stuff that slows me down" forum page... :)"
I'm sure there is one, you just have to hunt for a while to find it...  🙂
