Ability to mirror planes
Requesting the ability to mirror construction geometry to achieve the same angle and distance from a given object when adding features to an existing model. For example, I am redesigning a piece from our design for production, due to constraints on a battery module, there needed to be an angled door with a rail system to slide this battery pack into place, while also having the consumer able to remove the battery pack for charging purposes. I want to mirror the plane I had created earlier in the design used to create this door to the opposing side of the design in order to create a panel for an LED control module while still maintaining a primarily symmetric design. I can still achieve this, however, there are many more steps I need to go through due to the lack of this feature. Thank you for your consideration and I hope this information is useful in the improvement of this amazing program! Big fan of Fusion360!
1 Comment
Are you referring to mirroring sketch construction line geometry or are you referring to mirroring construction planes, axis, and/or points?
I think either way it would be nice to have an 'align' feature for the construction planes so that a person could snap the plane to certain position without manually manipulating it into place using the eyeballing method in collaboration with the right viewing angle or without entering in a coordinate distance in order to locate the plane where it is required.
