Invert selection on faces with multiple sketches for extrusion or other tools so that the user does not need to individually select each profile. Could be either toggled after the fact (i.e. Invert Selection as a check box on whatever tool you are using such as extrude) or activated on the fly by holding Ctrl / Command or Shift keys during selection. This would decrease the manual handling side of more complex work with multiple profiles and give another option than either patterning or multiple instances of the same function i.e. extrude many times over.
