Invert Selection on Faces
Invert selection on faces with multiple sketches for extrusion or other tools so that the user does not need to individually select each profile. Could be either toggled after the fact (i.e. Invert Selection as a check box on whatever tool you are using such as extrude) or activated on the fly by holding Ctrl / Command or Shift keys during selection. This would decrease the manual handling side of more complex work with multiple profiles and give another option than either patterning or multiple instances of the same function i.e. extrude many times over.
3 Comments
TrippyLighting
Invert Selection could and should work in many areas in Fusion 360.
Working right now, need to delete about 300 extraneous parts from Fusion.  I have a selection set of 15 objects I want to keep, but no way to delete what's NOT in my selection set.  Invert Selection indeed!!
TimeraAutodesk
Status changed to: RUG-jp審査通過
Thank you for your idea - this is getting archived due to lack of votes. Ideas with 10+ votes within a month are reviewed by the Product Management team for future consideration. If you feel strongly that this is needed, please resubmit with more detail on why you think this is valuable to Fusion 360 users so that the idea gathers some more support from the community.
