Please add the following features to the text in sketching
1) make them objects that can use and retain user parameters. The current implementation allows you to use parameters, but only by value.
2) Don't change the text size if the user manually specifies it. Endless loops seem to be created while working around the absence of feature request #4.
3) When dimensions and points are added to text box, allow those constraints to be retained after editing text size, font, value, etc. Currently points that are put on a text box will loose reference to that text box on editing the text.
4) Allow users to create, in addition to the horizontal tex:
a) Word Wrapped Text
b) Text along an arc
c) Text along a path (bonus points for this one)
5) Improve user ability to select text that has been extruded while using the CAM Engrave operation. Selecting all the contour lines of the text can become very tedious and performance degradation occurs when selecting many of these text contours.
