Generate Cross Section Sketches
I really need the ability to make a construction plane in the middle of a loft and gt a parametric cross section of a part as a sketch. I can think of a million ways to use it. Right now it would add to my lofting tools but making forms for large composite layups would be useful as well.
5 Comments
HughesTooling
Is getting the construction plane in the correct place the problem or the the parametric cross section? If you have the plane then Project Intersect will generate a parametric sketch.
@HughesTooling Perhaps I am missing something. Finding the proper sketch plane is not a problem. I can put them anywhere.However if I project a line passing at an angle through the plane I do not get a point I get a line. Am I missing a feature?
I cant seem to attach a file. Make two random closed splines 6 inches apart. Loft between them. Then make a plane in the middle and ty to trace the shape.
HughesTooling
Look on the project/Include submenu and use intersect not project.
Mark
I don't know why I was having a hard time with that. That is exactly what I am looking for!
Technology Administrators
