faster way to select face or body to call remove
if you want to call the remove command you need to select bodies
you have three ways:
select bodies in browser
select bodies via long press mouse and select body from parent context menu
switch to body select and select bodies
The browser can get filled with long lists and thus is not ideal.
Context menu is great for one object but takes too long for many.
Switching the selection type requires you later to switch you selection again.
So I would propose that via a key combination or shortcut we can either switch to certain selection types
or since bodies is very common switch to a temp body select so I can all remove.
Or include Remove in the main menu so I could call it like delete with an UI that then allows me to select
the bodies to remove.
Screen Shot 2016-09-09 at 8.54.46 AM.pngScreen Shot 2016-09-09 at 9.01.28 AM.pngScreen Shot 2016-09-09 at 9.01.35 AM.png
2 Comments
keqingsong
Thank you for posting your idea! The idea is now 2 years old and does not have many votes, so we are going to archive it. If this is still important to you, please make a new post with the idea included. You can follow the idea submission guidelines here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
