Exploded view rendering
Any chance an exploded view option could be added into the rendering workspace? It's in the online viewer already so doesn't seem too hard to implement....
4 Comments
If you want to render in Exploded View there is one trick for that which is,
First you manually explode from the Model of the toolbar, By moving the bodies.
Second then go to the Render tab and render the model.
jan.gladines
This is a workaround at best, not a solve. Not only is this way more time consuming than dragging a simple slider, it's also not possible if you have your design properly constrained with joints.
YEAH , that's right.
Hi Guys,
This has been a feature I have seen alot of poeple asking for. There are several 'ideaboard' posts asking for this - https://forums.autodesk.com/t5/fusion-360-ideastation/rendering-section-views-and-exploded-views/idi...
We were told this feature was on the nearterm roadmap in 2015, promising us we would be using it by 2016. I now speak to you in 2020 without the ability to render exploded views. We were also promised an exciting sounding combination of both the rendering workspace and the animation one.......well it sounded nice anyway, cheers for nothing Fusion.
