Pattern along a path, doesn't follow set path
Patterning a body along a path doesn't exactly follow the path as desired unless starting from a set point, just seems like it could be improved. I'm trying to follow the work around of patterning a point shown in:
https://knowledge.autodesk.com/support/fusion-360/getting-started/caas/screencast/Main/Details/7975a...
My use is a work around until the following is implemented:
https://forums.autodesk.com/t5/fusion-360-ideastation/sketch-pattern-along-a-path/idi-p/7271724
