Deform tool
Deform tool
Hi all
I would really like to see a deform tool similar to that which can be found in Blender and FormZ.
It could be one tool or a few separate tools. It should be able to twist and bend an object (maybe also bulge) around a nominated point on or off the object (e.g. twist the top face of a cube in relation to the bottom, left, rear corner of the cube, or twist it in relation to the world origin).
See this post for more information of where this could be useful: http://forums.autodesk.com/t5/Help-and-Support/Helical-sweep/td-p/5186239
Chris
4 Comments
If you're asking what I think you are, that might already (at least more or less) exist in the surface modeling mode.
Hi roambotics_scott, can you elaborate on this any further?
What tool should I be using?
Sculpt.
Long hangout - https://www.youtube.com/watch?v=wQAs0R_CCUI and a quicker example https://www.youtube.com/watch?v=6azefXBazXA
It doesn't quite do the solid modeling clay deformation stuff I'm sure you'd want but it'll get you pretty far with surface modeling.
keqingsong
Status changed to: RUG-jp審査通過
