Hi all
I have been trying to create a reel for a reel mower. The reel blade is esentially several metal bars with a sharpened edge that have been bent along a helical path and then welded to a number of circular metal plates. I tried to create this in Fusion 360 but gave up after a few hours. I was using the coil tool with a small (0.1mm) triangle section and then sweeping my profile along this shape.
The problem I'm having is that the profile seems to be pivoting around the point where it touches the path, as well as rotating to keep up with the helix. This means that by the time it has reached the bottom of my path, the cutting edge points in to the middle.
What am I doing wrong? Is there a better way to do this?
In Blender I was able to simply use a twist deformation and it worked a treat. Is there a nice easy way to do this in Fusion 360 (short of importing it from Blender)?
Any help would be greatly appreciated.
Cheers
Chris
