Create Box with centre rectangle
At the moment in Fusion 360, if you start with a Box primitive, you select a plane, then it goes straight into a 2-point rectangle. What would be great is if it when straight into a centre rectangle, this would then allow you to snap to the origin and draw a rectangle about this point, leaving the origin planes running through the mid planes.
2-Point rectangle
3 Comments
michallach81
I like this idea, same as I don't like how primitives works. It make no sens to create a sketch and not having access to it afterwards. The way in which this is done now, is misleading.
schneik-adsk
Status changed to: オートデスク今後検討
promm
Status changed to: オートデスク審査落選
This is a good idea and I have placed it in our backlog.  This is a longer lead project due to parametric work is being done on primitives that it will be a part of.
Thank you,
Mike Prom
