i feel like something important is missing.
When drawing sketches, and specially when often using mirror option, we need construction lines.
Way that Fusion is using this features is little bit annoying.
You must choose line, go to menu and select construction line.
To be true in parametric drawing construction lines are important - but in fusion 360 it looks like here that they are not most important thing.
It would be nice to add separate option to construction lines. I saw that solidworks strongly operate on construction lines.
There also should be possibility to add infinite construction lines and specially horizontal and vertical.
So I'm asking, voting for:
- separate option for creating construction lines (it can be in menu or shortcut, no matter)
- infinite construction lines
- lock selected construction line to be horizontal or vertical - when drawing new line.
