color codes for HEIGHT panel
 Depending on the viewing angle, I often have trouble reading the height-level labels. I think color coding on the HEIGHT panel would help.
4 Comments
 I completely agree.
Also, when two heights are the same and you are viewing from "on end" one can't see both colors. One hides the other. If you could make those 2 color lines appear as a set of bi-color dashed lines. You would immediately know that they are both at the same height. Sorry my olive lines aren't drawn straight but you get the idea.
keqingsong
Status changed to: オートデスク今後検討
This is a good idea that can be leveraged not only in CAM, but also throughout Fusion 360 where color coding is needed and improved. We are looking into this right now to see what are some things we can work on right away.
Thanks. I'm looking forward to it.
keqingsong
Status changed to: オートデスク審査落選
We are now working on scoping this project. Will keep you posted on when this will be available!
