CAM Simulation settings should remember settings
The Cam simulation command has several options for toolpath and stock. These options are not remembered when you run simulation multiple times. They should be.
entered by @schneik-adsk on behalf of @Anonymous from this thread: http://forums.autodesk.com/t5/computer-aided-machining-cam/saving-default-simulation-settings/m-p/57...
7 Comments
colin.smith
Status changed to: Gathering Support
al.whatmough
Status changed to: オートデスク審査落選
scottmoyse
This is needed in Inventor HSM as well.... and HSMWorks for that matter.
OFGLLC
This is a real pita.  Even defaulting the stock checkbox would help.  If you can't see fit to making persistent options, at least allow it to persist during the session!
michaelmaes
Would be very appreciated if implemented 🙂
This would be a great addition!
Would LOVE this !!! Just a simple right click "Make Default" option...
Every time I simulate a cut, which is a lot, I always change the following-
Tool- checked
       -Flute
Toolpath- Unchecked
Stock- checked
         -Material- Plastic Vinyl
Fusion does remember this within sssionsbut it would be really nice to make default.
