Boring, Drilling, Tapping Cycles: Order by selection
It would be nice to have the option of being able to post process the operations based on my desired order of drilling (tapping, boring as aforementioned), as opposed to the shortest, or most efficient solution as determined by Fusion. In other words, if I select bore 1, then 3, then 2, it will post the boring OP in that order. As it is, Fusion chooses which one to do first, as well as subsequent sequencing, which may not make sense given last tool position, how many cups of coffee you've had that morning, phase of the moon, etc.. I believe it has been available in the past, and been referred to as "preserve order"?
10 Comments
kb9ydn
It should already do this by default if you uncheck "optimize order".  If it doesn't I believe that's a bug.
C|
Ah, gotcha! Thanks! Unfortunately, the option still isn't there for the boring cycle, which actually brought the issue up for me.
kb9ydn
Oh ok, that boring cycle.  Yeah it's sort of dumb in that respect.  Sorting options definitely ought to be added.
C|
porsbym
Status changed to: オートデスク審査落選
Thanks for the votes on this one. We expect to start working on this very soon.
keqingsong
Good news! This is getting implemented in the up-coming January update!
Awesome! Thanks, guys!! Will be very helpful for several of my OPS!!!
keqingsong
keqingsong
keqingsong
 Woot! Thanks guys! Really appreciate it, Keqing!
