Array: spacing between objects option
current array does allow you to divide the distance and position objects there.
Screen Shot 2016-09-10 at 4.51.19 PM.pngScreen Shot 2016-09-10 at 4.51.31 PM.png
what is really missing is being able to array parts with a distance between the objects I can adjust!
as an example I will use Blender here: You can array objects next to each other
or define the space between them according to the % of the object width
Screen Shot 2016-09-10 at 4.57.38 PM.pngScreen Shot 2016-09-10 at 4.57.46 PM.png
in addition specifically for Fusion using a distance based on a unite value like 1cm or Dimension of an object would be ideal!!!
5 Comments
Solar-emc
YES PLEASE
What amazes me about this is. Back in 1985 we had this ability in macPaint and macDraw. I don't understand why this is not a standard in all graphics programs.
cekuhnen
@Solar-emc Well every CAD app has different philosophies and follows a workflow the users seem to use. Rhino today still shows its origin as a plug-in for AutoCAD.
colin.smith
Status changed to: オートデスク今後検討
Hi @cekuhnen
We have the ability to control the spacing value between each object in the pattern. Are you asking for the % to be added as an option?
Colin
cekuhnen
@colin.smith
Yes that would be fantastic. The current array tools in Fusion are fantastic with what it can do - specifically even leaving out steps.
But I found myself often wishing for using percentage to use as well.
The modifier in Blender uses the actual with of the object and when you say 1 then it places object next to object.
In Fusion you could do that as well but you would need to measure the object with first.
I am not sure how easy this would be for Fusion to implement because Blender just draws a bounding box around the mesh
and samples x y z from it.
colin.smith
Adding to the sketching backlog. Release date TBD.
