current array does allow you to divide the distance and position objects there.
what is really missing is being able to array parts with a distance between the objects I can adjust!
as an example I will use Blender here: You can array objects next to each other
or define the space between them according to the % of the object width
in addition specifically for Fusion using a distance based on a unite value like 1cm or Dimension of an object would be ideal!!!
