Allow Sculpt "Subdivide" to work on multiple faces (mesh--> solid conversion)
I frequently am asked to convert meshes into solids.  Until such time as Fusion automatically does this for me (...hopefully sometime soon!  🙂 here is my workflow, which works very well (except for this IdeaStation part I am asking for):
  • Import mesh
  • Go into Sculpt
  • Create Faces with object snapping manually (create face, then edge create)
  • Click Subdivide/Simple with snapping to better fit the surfaces (on every.single.face.one.at.a.time)
If the subdivide command could work on multiple faces at one time (allow all selected faces to be subdivided into arbitrary numbers (2 length 3 width or whatever) with snapping, it would save tons of time.
A simple change, but one that will help us with mesh-to-solid workflows.  Thanks!
1 Comment
nkloski
And just to be clear, if you preselect the faces, this works as it should, but only for that first selection. I want the tool to allow for multiple selections of faces while in the tool.
