Gravity Joint
Gravity Joint
Hi, i was creating a ferris wheel assembly. But somehow i cannot find the right joint to make the capsule stay upright. i found a solution in a different software called ProEngineer, they have this mechanism feature called Gravity which makes the capsules stay upright during assembly animation. Hope you can add more features like this in Fusion 360. I really like using Fusion 360 in Modeling my 3D projects. Thanks 😉
4 Comments
HughesTooling
You can get what you're after using Revolute joints and a motion link. Here's a screencast, if you want the file as an example start a thread in the design forum and I'll attach it, you can't attach files in the Ideastation for some reason.
Mark
This kinda gets to the crux of my annoyance with joints and motion
It's great for making animations, and even analysing the motion of simple linkage networks, but there's no real physics or mechanics there.
I can make a transmission that moves correctly, but it's not doing any of the work for me.
This would be a example test case for rigid body dynamics simulation because it would capture not only that the pods remain upright, but how they're affected by changes in motion. Start / stop the spinning, and they swing realistically based on linkages, mass distribution, and moments of inertia
AndrewSears
Hi Mark - Someone asked for the same thing a few months ago.  Add a gravity vector  Please add your votes to that one also.
Hi Scott - Can you review these ideas and vote for the ones you like?  Rigid Body type ideas
Andy
Hi Andy - Would do but can't.. I've already voted for every one that I'm eligible to and the others have something in common that keeps me from voting for them
