Ability to Edit Unit in Parameter Table for Existing User Parameter
After I have entered a User Parameter in the Parameter Table I may need to edit it.  I am able to edit the "Name" and "Expression" but not the previously selected "Unit".  This is very inconvenient.  The only way to edit the "Unit" is to delete the entire User Parameter and start over which is a big waste of time.
I cannot show this in a screen shot or ScreenCast so please test it for yourself.
4 Comments
I only can see this as a good thing for new and / or unused parameters.
g-andresen
I agree with you.
Especially parameters with variables require unnecessary overhead, if they need to be recreated.
in hope, that it will change soon
günther
s.david.baxter
I am also having the same problem, I can't change the Unit of Measure field without deleting and recreating.  This should be a simple fix, hope we see it soon as it is just another annoying little thing that has most likely been overlooked at some point.
ltomuta
At the very least when the units in document's settings are changed from "in" to "mm" ask me if I want all my defaulted-to-"in" user parameters be converted to "mm" as well.
