2d text on a radius path
Any word on when the ability to draw 2d text that follows a given radius?  I and many others have asked about this a few years ago but it hasn't been implemented in any of the updates yet. Seems like a simple fix considering all the cad ability the software has.
Thanks in advance!
3 Comments
mspecdesign
the only work around i've is to make it in a graphic design program like corel and export the wireframe as DXF then import to sketch.
but it would be nice to just do it in the program....or some version of it anyway
sparkytect
Community Visitor
Check out Inkscape. You can do anything you want to your text, save as a SVG & insert into Fusion.
Ive found this to be the best workflow, you might even find that you will almost completely finish the design in Inkscape, then this can be manipulated in fusion.
Hope this helps.
mattsc
Inkscape is the typically suggested workaround, but it's a bad one. The real solution here would be the obvious fix of just making it happen in Fusion in the first place. Aligning the text to a spline should be trivially simple to implement. It boggles my mind why this is STILL not implemented considering the number of times we have requested the feature.
