Pin Icon for "Ground" and "Unground" entry in component context menu
When right-clicking on a component, the "Ground"/"Unground" entry doesn't have an icon.
This makes the entry hard to find, as grounding has a prominent and recognisable pin icon both on grounded components and in the timeline, and I subconsciously search for that instead of the written word.
I think it would reduce confusion if that same icon was also present in the context menu next to "Ground". For "Unground", the respective timeline icon could also be used.
1 Comment
subversivespeed
Come see my topic.. We definitely need to streamline the use of such an important feature when building assemblies. https://forums.autodesk.com/t5/fusion-360-ideastation/grounding-should-always-be-in-right-click-drop...
My vision is that you select a face, body, component, and that ground/unground is always available in the right click dropdown, and it will simply automatically ground the entire component associated with whatever you have selected whether it be a face, spline, surface, body, component, etc and as long as that component related is valid, it will allow you to ground/unground without having to go to model tree on the left, thereby saving a huge amount of movement and clicking and searching.
