[OPEN] Looking for feedback on Mesh based workflows
Sualp.Ozel
Community Manager Community Manager
Message 1 of 86
Sualp.Ozel
Hi Fusion MFG community
As you may have noticed, the Mesh workspace just graduated from being a tech preview and is now a part of Fusion 360 user interface by default with the July 7, 2021 release. With this release you can:
  • Tesselate a solid body using triangles and/or quads to create mesh bodies.
  • Insert multiple mesh files including STL OBJ and 3MF
  • Interact with mesh bodies and face groups in both the parametric and direct modeling
  • Automatically repair broken mesh bodies.
  • Shell/hollow a mesh body
  • Combine / Separate mesh bodies
  • Generate face groups on mesh bodies and those convert mesh bodies to solid or surface bodies.
  • and more...
The workflows we implemented contains several intelligent default settings and the ability to preview the outcome of each command before executing them, so that users don’t have be an expert in working with mesh data to benefit from this functionality.
This release also comes with several known limitations:
3mf related limits
  • Upload 3mf is currently not supported
  • There is an inconsistency between Open and Insert 3mf workflows for assemblies (Open workflow display the component hierarchy, Insert workflow produces a single component with multiple bodies)
  • When exporting a 3mf, appearance and physical material are not exported as color information
Workspace related limits:
  • Mesh bodies are not supported as an input to Assemblies in Design workspace
  • Mesh bodies are not supported in Simulation workspace
  • Mesh bodies are not supported in Drawings workspace
  • Mesh bodies are not supported in Generative Design workspace
  • Mesh only components are not supported in Animation workspace when using Manual or Auto Explode
Face group related limits
  • Generate Face Groups feature is not designed for mesh bodies generated using scan data.
  • Accurate type within Generate Face Groups feature is not designed to find boundaries between complex curved surfaces.
  • Face group information stored in *.OBJ files is not loaded into Fusion
With upcoming releases of Fusion 360, we will
  • start eliminating the above known limitations.
  • continue to identify and fix new issues related to mesh workflows
  • improve the functionality around hollowing mesh bodies and
  • introduce new methods for converting organic mesh bodies to solid more effectively.
We also would love to hear back from you.
So here are some of our questions:
  • Have you experienced any issues importing / working with / editing mesh data in Fusion 360?
  • Can anyone send us examples of models you are experiencing such issues?
  • What would you want us to focus on for improving mesh based workflows?
No “Insert mesh” + “convert to solid” failed feedback please. You need to “generate face groups” before attempting to convert mesh bodies to solid bodies first 😊
There are no wrong answers here, we are just looking to start a conversation on how you plan to utilize the new mesh functionality in your workflow.
All questions, comments, and criticisms are welcome.
Sualp Ozel, PE
Senior Product Manager
Additive Manufacturing
Sualp Ozel, PE
Principal Product Manager
Replies (85)
Message 61 of 86
mattwnugent
Would love to see MeshMixer's brush based "Sculpt" tool available directly in Fusion 360. Especially if the Fusion 360 implementation includes MeshMixer's auto mesh refinement when brush sculpting.
Our current workflow is:
  1. Model in Fusion 360 (including Forms)
  2. "Save as Mesh" to MeshMixer
  3. add artistic touches with brush based surface Sculpt tool
  4. export STL for slicing and 3D printing
Would love to keep this workflow entirely within Fusion 360. Currently Fusion 360 handles every step except 3.
Message 62 of 86
hfcandrew
What are you making?
There should be a organic mesh modeling update coming in the next months.
I've said previously:
MM should be 100% integrated with Fusion. Given the advancements 3D printing, the usage of Meshes, the prominence of 3D scanning and reverse engineering, and also specifically in my field the usage of CAD/CAM/Print for orthopedics & medicine, shouldn't that be the obvious end goal? Now even moreso with the official announcement of the abandonment of MM development & support. Surely cannot just let such a great swiss army knife die. I gladly pay for this.
Message 63 of 86
mattwnugent
Minature figurines, display props, and accessories. Some definitely have an organic look and MeshMixers Sculpt tool is indispensable for this.
Do you have a source for the "organic mesh modeling update"? A search did not yield anything. I would be interested to see what new features are to be expected.
Message 64 of 86
hfcandrew
https://youtu.be/MlbHz1rlppU?t=2933
And read the splash screen: https://www.meshmixer.com/
And I had a web meeting with some sales reps a few months ago, they said ya in the works for next year.
Message 65 of 86
Sualp.Ozel
We the video is accurate. We are planning on releasing a  3rd mesh conversion option better suited for organic shapes in early 2022. In addition, we have focused our efforts to eliminate a lot of the shortcomings I recorded in my original post. So be on the lookout for a lot of improvements & bug fixes around Uploading 3MF files to Fusion 360, 3MF support with colors and textures, and improved support for mesh bodies in rendering. I hope to roll out these changes in the first half of 2022.
Sualp Ozel, PE
Message 66 of 86
Sualp.Ozel
Thank you for the feedback. I agree, it would be very useful to have Mesh sculpting tools in Fusion 360 in the future. However we are not actively focused on those workflows right now.
Sualp Ozel, PE
Message 67 of 86
hfcandrew
Amazing. Will this have any of the organic mesh modelling tools of MM? Such as soft transform with a falloff. Or Smooth boundary of a selection?:
https://help.autodesk.com/view/MSHMXR/2019/ENU/?guid=GUID-AF536B4D-4BCF-41EF-AD66-38A3E161E467
https://help.autodesk.com/view/MSHMXR/2019/ENU/?guid=GUID-E668ED29-8943-4534-A2B4-45135297FF3C
Message 68 of 86
JeffBradway
One workflow that I have been struggling with is modifying face groups. Often I can use the Accurate method to initially generate face groups for a mesh body. This works out very close to what I want most the time, however, if the mesh groups cross a natural hard edge the resulting solid body either fails or you get messy geometry. To fix this you can select the face group(s) in question and re-generate just those with the Fast option and choose a small angle. BUT then you have to combine LOTS of triangles that were already grouped originally.
It would be a LOT faster if there was a command called Edit Face Group where I could choose to remove certain triangles from a face group. Even better if the command would allow me to select individual triangles from a neighboring face group and steal them for the current face group.
Message 69 of 86
TrippyLighting
@JeffBradway I agree. The current workflow required to edit face groups is very clunky and inefficient.
Message 70 of 86
hfcandrew
Yes. In the meantime until F360 fully/properly integrates Meshmixer, just
do it in Meshmixer.
1) Edit>Generate Facegroup
https://help.autodesk.com/view/MSHMXR/2019/ENU/?guid=GUID-5E91C94A-1D1B-46D4-BF09-776BE74F12A3
2) Select>Modify>Create Facegroup
https://help.autodesk.com/view/MSHMXR/2019/ENU/?guid=GUID-5E4A1BE8-4009-4A61-8953-53E64624E943
3) Export as an .obj (per vertex colour)
4) Import back into Fusion
Watch: https://autode.sk/3L7xqZx
Message 71 of 86
JeffBradway
I did find a decent work-around. First double click the mesh to enter the direct edit mode. Then there is the command to create a face group. When you use that command it steals triangles away from any other existing face groups. Then you can combine that new face group with the one you want, or leave it as its own. Working in the direct edit mode also has the advantage of being faster and not generating as much history that Fusion will have to run through.
Message 72 of 86
jean-michel_legoff
Yes, That's also what I was wanted to suggest.
At least, I do it like this.
Message 73 of 86
RaceCarEngineer
Here is my feedback. Over the last month, accurate 3D scanners get much more affordable, so I guess a lot more people are going to use 3D scans in Fusion.
- Fusion slows down a lot if Meshes bigger > 100 Mb are imported. Even a small part is often bigger than that. So dealing with big data must be improved.
- To not slow down Fusion too much, the 3d scanned mesh must be reduced so much, that the geometry is getting a lot less accurate. Consequently, reverse engineering gets less accurate. So the super-accurate 3D scans are not worth anything if they can not be used in full resolution in Fusion.
- I used to make face groups for critical areas (bores, mounting points etc.) and then invert the selection, to only reduce the mesh on non-critical areas. This works usually for one operation. If I want to reduce the mesh a second time, Fusion brings up a failure message and can not do the operation. I'm not sure if this is a bug or if there are limitations between the border of high and low-density mesh.
- I'm really missing proper geometry detection tools like those found in GOM inspect.  This is really important and speeds up reverse engineering and makes it more exact.  ATMO in Fusion, a simple plane can only be defined by 3 points. The proper definition should be done with a Gaussian algorithm to best fit a plane to the scanned surface. Tools are needed to quickly define and measure regular geometry, like inside-, outside diameters, rectangular surfaces.
Here is a good video. All he does in Gom inspect before he imports the model into Fusion, should be possible directly in Fusion https://www.youtube.com/watch?v=V3xAwpENbU4
- Lastly, I would like to import point clouds directly into fusion, clean them up and finally mesh them adaptively. So critical areas should have high-density mesh, non-critical rough mesh. This could help a lot to bring the file size down and speed up Fusion.
Message 74 of 86
awilliamwright
I know you guys are working on most of the issues I have with the Mesh workflow, but I was curious if there is any talk about having "repair mesh" be an embedded option in the 3D printing export dialogue. It's not a big deal, but some slicers out there are very bad at repairing meshes themselves, and even Preform apparently uses a Fusion utility when it repairs meshes.
So, when I need to fix an exporting STL before it will print, I have to open a separate project, re-import the mesh Fusion just made, repair it, and then re-export it. It doesn't take that long and it usually works great, but it feels a little silly.
Message 75 of 86
hfcandrew
Ya. And Windows 3D Builder currently has without a doubt the best mesh
automatic mesh repair of any software out there. Talk to those people, see
what kind of sorcery they coded for that.
Message 76 of 86
amagicmerlin
I've returned to trying out the Mesh Environment in F360 during the Trial Extension period to try out the mesh to solid conversion tools.   So far, nothing I have works with the converter (and I suspect this is my inexperience) despite hours of working with re-meshers, blender, Insta-Meshes and others to prep and simplify mesh files.
In doing all this a number of points struck me that I WISH were in Fusion:
1.  A mesh simplifier that included a change to Quad Meshes for manual work towards a form.  Maybe a plugin for insta-meshes (flawed) could do this, but I'd like to see something reliable developed.
2.  A Mesh Scaler tool that would allow a mesh to be precisely scaled between two (or 3) vertices for exact linear scaling, and exact X/Y/Z transformation.
3.  (Most Useful) A way to 3D sketch on a Mesh using Vertices as Points (so you don't have to use the create mesh section tool to create surfaces or sectionally recreate a mesh  object as a solid.
e.g. below is a Miata Dash Tombstone in both basic mesh form and an imperfect 8K quad re-mesh of the OBJ file.  Neither auto-converts to a solid, but heck with a very small selected set of vertices points I could EASILY create a 3D sketch with lines and arcs between points & then use surface lofts between them  + thicken to recreate this as a solid. Far easier than trying with section sketches. (All this if I were dead certain the scale of the mesh were correct).  Perhaps this suggestion would be better parsed to the Sketch Interface Team?
Also better support for 3MF because as I understand it, that format can ALSO do Quad Meshes as WELL as contain measurement data & color data etc.
~Paul K.
Message 77 of 86
jean-michel_legoff
Did you try to edit face groups before trying converting to solid?
Message 78 of 86
amagicmerlin
Thanks for the suggestion.  Yes doing an edit on face group to reduce mesh count does help to an extent, and allows a partial body to be generated.  It's a start.  But it does bring up another suggestion.
If one could 3D project (include 3D geometry of the outline) of a face group, THAT would be a useful thing, instead of just being able to project a mesh body cross section geometry on whatever XY plane a sketch is attached (similar to create mesh section sketch I suppose).
I'm sure much of this comes down to my own inexperience in this work flow, but these were a few things that struck me as features (if available) that could make the process (from whatever way one attacks it) easier.
These were all just practice items.  The Tombstone seemed like one of more *simple* STL/OBJ files I have that would be nice as a solid instead of a mesh.  I'll probably try the organic conversion before time runs out.
Anyway, maybe these suggestions will inspire some updates.
~Paul K.
Message 79 of 86
awilliamwright
converting triangle-based meshes to quads is a much more complex ordeal than you might think. The only software I know of with a truely robust tool for this is the full version of Zbrush.
At the moment fusion simply can’t do much with triangle-heavy meshes. They’re just too complex to transform into CAD elements.
Message 80 of 86
jean-michel_legoff
In the Autodesk Portfolio there is also "Recap Photo" which is a good candidate as a Quad remesher...
you have an export setting dedicated for Fusion (Quad in medium quality)  if I remember well.
It should be a good idea to include those algorithms in Fusion directly...
@Sualp.Ozel
