Why does a grounded component move?
lemelman
lemelman
I've got a simple model consisting of two arms linked together at one end with a revolute joint, and I've grounded the top arm. As expected, I can move the bottom (ungrounded) arm, but not the top one. If, however, I animate the joint, the top (grounded) arm moves and the ungrounded arm remains stationary. Am I missing something?
Video_2023-03-05_144719.wmv
Video Player is loading.
Current Time 0:00
Duration 0:57
Loaded: 17.08%
Stream Type LIVE
Remaining Time 0:57
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • en (Main), selected
    (view in My Videos)
    jhackney1972
    Please refer to @jeff_strater post for a better answer.
    John Hackney, Retired
    jeff_strater
    Animate Joint only exercises the specific joint created, not the whole system.  So, all other joints are ignored.  This is the one place where the order in which you select the components when building a joint is significant.  Animate Joint shows the first component selected moving.  Try using Animate Joint Relationship (used to be called Animate Model).  It will obey all joints in the model.
    ground and animate.mov
    Current Time 0:00
    Duration 1:07
    Loaded: 14.77%
    Stream Type LIVE
    Remaining Time 1:07
    1x
      • Chapters
      • default, selected
      (view in My Videos)
      Jeff Strater
      Engineering Director
      lemelman
      So, under certain circumstances, grounding a component doesn't actually ground it. I've accepted your solution but fail to see the logic.    It seems rather like a case of--
      'When I use a word,' Humpty Dumpty said in rather a scornful tone, 'it means just what I choose it t...
      davebYYPCU
      Grounding does work, including Animate Model,
      and is only released with Animate Joint.
      Any other time it’s not working, should be reported.
      Might help.....
      jeff_strater
      "So, under certain circumstances, grounding a component doesn't actually ground it"
      No.  This is specific to this one command.  I agree that it could be confusing.  Animate Joint is exactly what it says:  It animates THAT joint, in isolation from the rest of the system.  This is the same thing that you see when you create the joint, and click the Preview Motion button in the dialog.  That preview, also, temporarily ignores all other joints in the system.  The ground is there and still active for any system-wide animation (Drive Joint, Animate Joint Relationships, component drag, etc)
      Jeff Strater
      Type a product name
      ______
      icon-svg-close-thick
      Cookie preferences
      THIRD PARTY SERVICES
      icon-svg-hide-thick
      icon-svg-show-thick
      Qualtrics
      Akamai mPulse
      Digital River
      Dynatrace
      Khoros
      Launch Darkly
      New Relic
      Salesforce Live Agent
      Wistia
      Tealium
      Upsellit
      CJ Affiliates
      Commission Factory
      Typepad Stats
      Geo Targetly
      SpeedCurve
      Qualified
      icon-svg-hide-thick
      icon-svg-show-thick
      Google Optimize
      ClickTale
      OneSignal
      Optimizely
      Amplitude
      Snowplow
      UserVoice
      Clearbit
      YouTube
      icon-svg-hide-thick
      icon-svg-show-thick
      Adobe Analytics
      AdWords
      Marketo
      Doubleclick
      HubSpot
      Twitter
      Facebook
      LinkedIn
      Yahoo! Japan
      Naver
      Quantcast
      Call Tracking
      Wunderkind
      ADC Media
      AgrantSEM
      Bidtellect
      Bing
      G2Crowd
      NMPI Display
      VK
      Adobe Target
      Trendkite
      Hotjar
      6 Sense
      Terminus
      StackAdapt
      The Trade Desk
      RollWorks
      Your experience. Your choice.
