T spline API in Fusion 360
moistwood_cao
moistwood_cao
Hi guys! I want to create a script in Fusion 360 to control my T spline model, but I cannot find any API about T splines in Fusion Help...... Can you guys do me a favor?  Thanks a lot!
By the way, is there any NURBS tools in Fusion 360?
sutherland-
Hi @moistwood_cao
Below I am quoting one of the Fusion 360 members from 2021.
"Unfortunately, I don't think the API for operating the T-spline Body is open to the public.
In the past, there was a discussion in the Japanese forum about using the API to manipulate the vertices of a T-spline body.
At that time, I searched the web and found this document.
https://iranarze.ir/wp-content/uploads/2016/11/E524.pdf
It was too difficult for me to understand.
Also, I found this package on github.
https://github.com/GrapeTec/T-SPLINE
There is a tsm file in the rhino folder.
I imported it with this add-in that I have published, and it seems to import correctly.
https://github.com/kantoku-code/Fusion360-TSplineBodyDoorway
I think the format of the tsm file in Fusion360 is the same as the one in this package, so I think it may be possible to use it."
Hope this helps in any way.
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
moistwood_cao
Wow thanks a lot! I am reading a lot of documents about T spline and NURBS. Say, the T spline Tools seem hard to parametrize the model. In github I found the GrapeTec T spline too. This project focuses on the T spline kernel based on 3 layers and used in Rhino.
Maybe the github is a solution temporarily,or tuse parametric modeling to control points on the T spline 3D Mesh.
Anyway, thanks for help!!!!
sutherland-
@moistwood_cao
I am glad that we found a solution (at least temporary).
Have a great day.
Best regards,
Level  sutherland-
Member
mhoffmannPNLWG
Has anything changed here?
