All flanges facing in?
tmostad
tmostad
How do I get all four flanges facing in? I created a rectangle, extruded it, converted it to sheet metal, then added four flanges all facing up. Now I want to add a flage to each side facing in. I can't seem to do it and have all of the corners mitered. I figure I am missing something obvious.
laughingcreek
make sure you picking the edges on the same relative side (all inside or all outside)-
tmostad
Thank you! Yes, I knew it had to be something obvious. Working with very thin sheet metal it is easy for me to forget it is a three-dimensional object. Perhaps if I did more sheet metal work it would sink in.
TheCADWhisperer
@tmostad
Walk your way through the Timeline of Attached file...
