Hi friends!
Here`s a problem i stuck with for a while...
Below you can find the link with nonstandard geometry sheet metal panel.
Could you help me, is there any way to miter the flanges manually?
I know that if flanges were with same angles, miter flanges should be cut with angle automatically. But here`s another situation...
Attached pic. how it should look.
Thank you!
Solved by TheCADWhisperer. Go to Solution.
Your Sketch2 is not fully constrained - it has an unnecessary line that is not fully defined.
You used 2 lines.
I used 1 line and 1 sketch point on that line.
I did not investigate further since I do not have any experience working with under-constrained sketches.
